If you meant 07, upgrade to 750's in the back, keep the stock ski locker bag, and get a open bow sack or integrated bow sack and run with the wakeplate 3/4 of the way up at 24.5 and you're set. Open bow sack up front will give you a total of 3000 lbs liquid ballast and a pretty good balance, you can also go with the integrated bow sack (under the seats) and get 2500 lbs ballast. Good luck bro.
