Old     (rexlex01)      Join Date: Mar 2010       03-11-2016, 1:13 PM Reply
Advice needed for the following products for a sub box?
1) http://www.menards.com/main/building...30-c-13338.htm
2) http://www.menards.com/main/building...95-c-13332.htm
3) http://www.homedepot.com/p/T-G-Drypl...9058/202522977
Also, is 1" MDF that much better?
Old     (timmyb)      Join Date: Apr 2007       03-11-2016, 1:47 PM Reply
This one is a safe bet. I don't know anything about #3. If you can avoid using MDF, you should.
Old     (Truekaotik)      Join Date: Jun 2012       03-13-2016, 5:43 PM Reply
Birch is good to use and lighter than MDF. Resin coat it and it will outlast you owning it.
Old     (london)      Join Date: Mar 2016       03-18-2016, 8:57 PM Reply
^^^ like he said birth. i wouldn't use mdf in a boat for some reason even with resin it still gets moisture and falls apart.
Old     (phillywakeboarder)      Join Date: Sep 2008       03-20-2016, 8:11 PM Reply
I build all of mine out of Azec. It's basically indestructible, totally impervious to the elements, and a joy to screw together - never spits, etc.
Old     (rexlex01)      Join Date: Mar 2010       03-20-2016, 9:17 PM Reply
Is Azek more flexible than Birch?
Which would be stronger?
Old     (denverd1)      Join Date: May 2004 Location: Tyler       03-21-2016, 6:09 AM Reply
Im thinking about some HDPE. Its not cheap, but I don't to rebuild it.
