Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 21, 2008
Old     (superwake220)      Join Date: Feb 2008       02-10-2008, 10:06 PM Reply
I have a Supreme V220 with the Proflight Swoop tower on it. I made a fiberglass speaker enclosure for it and I was trying to find out what is the best way to run the wires for it. Any help would be great.
Old     (ralph)      Join Date: Apr 2002       02-10-2008, 11:16 PM Reply
Drill your holes top and bottom. Tape a vacuum to the bottom hole, feed a leader string in the top and the vac will suck it out the bottom. Attach your wires and pull. Too easy.
Old     (hamkj)      Join Date: Apr 2002       02-11-2008, 12:26 AM Reply
I used dental floss to get the leader string through... then pulled a stronger wire through with the dental floss... then pull the speaker wire through... in addition... I pulled through some more wires for lights and nav light and RopeWinder...
Old     (266crownlinebr)      Join Date: Apr 2007       02-11-2008, 1:38 AM Reply
Run the wires down the side closest to the amp/head unit.
Old     (elc)      Join Date: Jan 2008       02-11-2008, 9:22 AM Reply
I tried the vacuum and string but the string kept getting hung up on something inside the tower. I ended up using a wire puller that I had previously purchased to pull speaker wires through the walls in my home and it also worked.
