Jim, What time of year are you going? If you plan on spending time in/at the Marina....Wahweap is much more user friendly & you have Page, Az a very short drive away if you need anything. If you are planning on getting far away from the marina, I guess it doesn't matter much where you are launching out of.... Whichever is closer is probably the better destination. We always stay fairly close(a canyon or 2 away) because we gas the tow boats at the marina. I do not think that there is a noticable difference between the sides. Though now that you cannot shoot right across at Wahweap, I feel it takes a little longer to get away. Then again, if you go out of Antelope Point....you avoid some of that....and they rent houseboats not....so that is an option. As far as how much gas, do you mean with the houseboat or tow boats? The houseboat is going to use a lot of gas. Depending on what time of year you go & if you are using central air....it could use a ton. Also, depending on how far you take the houseboat up/down the lake....bla...bla...bla....
