Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through June 18, 2006
Old     (bailey)      Join Date: May 2001       05-22-2006, 3:15 PM Reply
I am looking at ordering some bindings off the internet. I have a pair of System Bindings from 2002 (blue ones) and I love them. Problem is I ripped them out. I saw some 2004 Systems on ebay (yellow ones). The pictures look the same but...
Are they the same binding or did they change over the two years.
Thanks a lot
Old     (ozwest)      Join Date: May 2006       05-22-2006, 3:37 PM Reply
I'm no expert but here's what I found on wakeworld.com's reviews. Hope it helps.
2004:
http://www.wakeworld.com/boots/getboot5.asp?ProductID=2300
2002 (your bindings):
http://www.wakeworld.com/boots/getboot2.asp?ProductID=1439
Old     (jjakober)      Join Date: Apr 2002       05-23-2006, 7:14 AM Reply
They removed the extra wraps that went through the little notches in the clamp pieces, and the inside material was softened up a bit to make them more comfortable. Also the pull strap was changed on the heel piece.
Later,
jjakober
Old     (bailey)      Join Date: May 2001       05-23-2006, 9:53 AM Reply
Does this make them not as supportive?
I have really bad ankles and I loved how stiff and supportive my old pair was. I can't find anything comperable in the new bindings.
Thanks
Old     (innov8)      Join Date: May 2005       05-23-2006, 9:59 AM Reply
If you are lookin for somthing stiff with alot of ankle support, then check out the 06 CWB Fuse. This binding has tons of ankle support.
www.ridecwb.com
Old     (jarrod)      Join Date: May 2003       05-23-2006, 10:02 AM Reply
Exactly. I'm currently riding the fuses. They are a little stiffer, but not too stiff.
Old     (jjakober)      Join Date: Apr 2002       05-23-2006, 2:12 PM Reply
If you are looking for a stiff binding that is more up to date, then check out the O'Brien Xenon http://www.wakeworld.com/boots/getboot7.asp?ProductID=3035 or Radon http://www.wakeworld.com/boots/getboot7.asp?ProductID=3201. Both these bindings offer great ankle support and are super comfortable.
Later,
jjakober
Old     (bailey)      Join Date: May 2001       05-23-2006, 3:22 PM Reply
I think I tried on all those suggestions in the last week. Unfortunately none were as stiff as the old systems.
Thanks for the input.
Old     (kristian)      Join Date: Nov 2002       05-23-2006, 3:45 PM Reply
have you tried the 3ds' they're pretty dam stiff.
Old     (jjakober)      Join Date: Apr 2002       05-23-2006, 4:42 PM Reply
That's interesting, I used to ride the Systems and I would say the Xenon's are stiffer then the Systems and the Argons are at least as stiff as the Systems. I guess that just show's that everyone is different!
Good luck in your search.
jjakober
Old     (andy_nintzel)      Join Date: Sep 2004 Location: Minnesnowda       05-23-2006, 5:20 PM Reply
I am a expert. They are exactly the same bindings as the 2002
Old     (team_o)      Join Date: Jun 2002       05-24-2006, 6:28 AM Reply
No - I am an expert!!!
The difference between 2002 and 2004 is the 04's have a better footbed, and the inner material on the heel & toes is much more comfortable.
Also the sizing on the 04's may fit a bit smaller so factor that in when you buy. I think in the 02's a large was a bit big for me and in 04 a large was just right. (I have a small size 10 foot)
Old     (team_o)      Join Date: Jun 2002       05-24-2006, 6:30 AM Reply
Although I would agree with J Jakober that the Radon's are just as stiff (if mot more so) than the 04 Systems and a way better binding - in comfort and performance.
(Message edited by team_o on May 24, 2006)
