Can anyone tell me where the water intake is? I want to attach a garden hose T connector so I can run RV coolant through it. Has anyone added a T connector on a 330 before?
The raw water inlet is probably near the transmission or vdrive. There should be a hose than comes from a through hull fitting. That hose probably runs to the transmission cooler or through the transmission.
I have never actually worked on a Black Scorpion bu this seems to be where most through hulls are located.
Mine's a d-drive but the raw water pump is on the bottom left corner when you look at the belt. The back of the pump has the upper hose for raw water and the lower hose goes to the circulation pump in the center of the belt. The raw water intake is on the starboard side of the hull about 1/4 from the stern.
There's a posting on CenturionCrew in the mods section with pictures and a detailed writeup on a 330 scorp. I think there the word 'flush' in the title.
