Old     (Ccamp2)      Join Date: May 2012       06-07-2015, 10:03 AM Reply
I tried searching for other posts to answer my questions but couldnt find a solid answer.
Given the below pictures I have 2 questions:
1) With the white color controller being supplied power by the DC plug in how do I change that to hook to a switch on my panel?
2) Do I connect a wire to all 4 copper spots? and if so why gauge wire? (R,G,B, 12v)
Old     (cain0725)      Join Date: May 2012       06-07-2015, 2:48 PM Reply
run your hot from one side of switch to the LEDs,, i used 22 gauge 5 pair wire. But i do have color changing RGB from wetsounds,, works awesome.
Old     (grant_west)      Join Date: Jun 2005       06-08-2015, 5:34 AM Reply
this should help you out and yes 22 agw is good stuff
http://youtu.be/0E2C_gHopH4
Old     (Ccamp2)      Join Date: May 2012       06-08-2015, 1:21 PM Reply
Thanks Cain and Grant.. I got it now on how to connect them together.
Still not sure hot to connect the RGB "white box" to the switch ? Or do I not need to
Old     (cain0725)      Join Date: May 2012       06-10-2015, 5:28 PM Reply
RGB box needs to be run straight to perk switch if you have one, otherwise run to a separate switch , then you will use the remote control to turn on and operate.
Old     (Ccamp2)      Join Date: May 2012       06-12-2015, 11:36 AM Reply
Cain I have a perk and extra switches available on my panel.. the white box only has a DC plug in as I see.. how do I cut off the end or??
