Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through January 14, 2005
Old     (elcarteros)      Join Date: Jun 2004       12-04-2004, 9:43 PM Reply
I have a 01 Mobius w/ a 350 in the locker and a 550 and a 300 in the back. Any one else weigh differently?
Old     (santa)      Join Date: Jun 2004       01-05-2005, 10:13 AM Reply
I'm just starting my winter project of adding more weight to my 04 Mob LS.
I was looking at around 400# in the front locker, plus another 450# in the rear locker (yes, I've re-inforced the floor of that locker!). That's in addition to the factory tank under the back seat of roughly 400#.
You'll have to wait till next spring to find out from me if this worked out ok.
Old     (wakedoctor)      Join Date: Dec 2004       01-05-2005, 1:23 PM Reply
i thought weighing any boat was the same, 40/60 on direct drives, and 50/50 on v-drives.
Old     (seattle)      Join Date: Mar 2002       01-05-2005, 4:06 PM Reply
350lbs in the nose
factory 300lbs in the locker
two 550lbs either side of the motor
one 550lb sack in the back.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       01-07-2005, 11:42 AM Reply
damn cliff, any pics of the wake?
Old    downside_up            01-07-2005, 11:50 AM Reply
Last weekend in my 2001 Air Nauti we had 400# stock in the back, 375# on top of that, 400# in the locker, 450# in the bow, 250# each side of the engine, and 170# lead in the bow. Grand total~2245# + 2 guys, 2 girls, 1 kid. The wake was nice, but I think we're going to go to side seats and raise it another 300-400#.
Anyway, you should probably add up front. Like they said : 60/40 back/front
(Message edited by downside_up on January 07, 2005)
Old     (smokedog2)      Join Date: Dec 2004       01-07-2005, 12:29 PM Reply
Does anyone worry at all about the weight capacity of the boat as posted? Just from the standpoint of staying above the water line I would think some of this is getting a little crazy.
Old     (wakedoctor)      Join Date: Dec 2004       01-07-2005, 2:21 PM Reply
weight capacity, what is that?
Old     (pierce_bronkite)      Join Date: Jul 2003       01-07-2005, 2:31 PM Reply
Jeff, welcome to wakeboarding.
Old     (seattle)      Join Date: Mar 2002       01-07-2005, 3:38 PM Reply
Nacho,
I rode in that boat before I bought mine. It's the main reason I went with mine. With that weight configuration, you get a large firm wake with a nice transition. I run 1000lbs in the locker and a 550lb on either side of the motor. My hull is essentially the same as the inboard version.
Old     (speakersox)      Join Date: Sep 2004       01-08-2005, 9:59 PM Reply
I put 350lbs in the locker of my Mobius until I found out that the fuel tank sits under the locker along with all the related hoses. Dealer said that the locker was designed to hold no more than a 100lbs evenly distributed. I have had the boat for two years and still can't find the perfect wake on it.
Old    cws_kahuna            01-11-2005, 10:15 AM Reply
Reuben,
I have 2001 mobius. I use the Skylon Locker sack -claims to be 600lbs. I use a fly high tube sack under the rear seat along with some sand bags probably about 450-500lbs. I also have another 400lbs in easily movable weight. I tried to make it so all of my added weight was out of sight.
Be careful in adding a ton of weight in the back storage compartment. It was not designed for a lot of weight but can be reinforced. There have been issues with people messing up their gas tanks putting to much weight in the very back on the Mobius-this may have changed on newer models.
(Message edited by cws_kahuna on January 11, 2005)
