Go Back   WakeWorld > >> Wakeboarding Discussion Archives > Archive through February 23, 2009
Old     (treycleaton)      Join Date: Mar 2005       02-17-2009, 7:42 PM Reply
Looking at these on closeout. I wear a 9-10 shoe depending on brand. would size 9 pb floyd's fit me OK? Anyone know if they are true to size or run small/large? Much appreciated.
Old     (jdwake1)      Join Date: Sep 2007       02-17-2009, 8:27 PM Reply
They run small I just ordered a 11 and they sent me a 10 which I thought I might be ok with and had to curl my toes. I wear a sz 10 1/2...
Old     (sidekicknicholas)      Join Date: Mar 2007       02-17-2009, 10:17 PM Reply
I wear a 12/13 shoe pending the company and wear 12 D2's and after the heat molding they're great
Old     (wakerider111)      Join Date: Jul 2006       02-17-2009, 10:20 PM Reply
i thought the sizing was pretty true... but i suppose it is very subjective matter eh?
i got 11 size D2 and i have 10.5 size foot. in the store i thought the 10s were to tight (toes more then just touching the end... a little cramping, but this is without heat molding...). BUT later, after some use, i decided that i wanted a little less room in the toe-box and inserted a cut up piece of foam in the bottom of the boot under the liner to squeeze things up just a tad... just an idea and to tell my experience. i guess my philosophy at the time was, "it'd be easier to get a size too large and ADD TO it then to take away from a size too small"
go to a store and try a SS boot on to get an idea if you can
OR
wherever you are buying it from might be able to switch the size if you don't like it within a period of time? contact them and ask
(Message edited by wakerider111 on February 17, 2009)
Old     (waketac)      Join Date: Apr 2002       02-18-2009, 12:02 AM Reply
I usually wear size 10 sneakers. I tried on the 2008 PB Floyd in Size 10 an my toes were more than just touching the front of the liner. Now I've gotten a size 11 and they are just fine. Yet I've never liked my boots to be very thight in the front.
Old     (lakemiltonwake08)      Join Date: Oct 2008       02-18-2009, 5:11 AM Reply
I wear a regular shoe in size 10. My toes are snug in the PB Floyds in 11. They run a size or so too small.
Old     (treycleaton)      Join Date: Mar 2005       02-18-2009, 7:04 AM Reply
Cool, thanks guys. Looks like I should order a size ten, and go from there....
Old     (zach2orjack)      Join Date: Dec 2008       02-18-2009, 9:16 AM Reply
I agree with Nick. They run a size small or they did with mine. I got an 11 and had to return them for a 12.
Old    Slingshot            02-18-2009, 9:27 AM Reply
The boots run a little small, if you wear a sz 9.5 shoe, I would recommend getting the sz 10. If they don't fit right just call us and we will get you the correct size 509-427-4950 ext 23
