05-22-2006, 10:27 PM
my cousin hit an underwater stump in his 19ft sea ray. he has a 350 engine w/ an alpha one outdrive. the shop says he needs a new outdrive which will cost him $9000. he has no insurance, my question; is there a reputable site or business that sells used outdrives or parts salvaged from wrecked boats?
05-22-2006, 10:58 PM
My question is why he has NO insurance
05-22-2006, 11:20 PM
who cares, he doesn't for what ever reason. An outdrive shouldn't cost that much.There are lots of outdrives around, especially the alpha. How much transom damage was done?
05-23-2006, 3:00 AM
I haven't dealt with any of the organizations but there are lots of shops available in a google search. The one at this link is a Mercrusiser platinum dealer, meaning they do significant volume, have certified mechanics, and have received good customer feedback. http://www.outdrives.com/merc/mcost01.html Is a complete unit required or just the lower end?
05-23-2006, 4:33 AM
"who cares, he doesn't for what ever reason" What? are you high or something? Firstly, If you have no insurance you are in my opinion an idiot. secondly, who cares when he chops up a swimmers leg with his prop? or crashes into another boat and takes out a few people? What an absolutely ridiculous comment to make. Sorry to say it but he deserves to have his boat wrecked if he took that kind of risk. The guy should not be on the water. There's my 2 cents, unlike others on here i will not be recommending a place to get the boat fixed.
05-23-2006, 4:43 AM
Brit rider - I don't think Fiberglassman is saying it's Ok to not have insurance. I just think he means that's not really the topic here.
05-23-2006, 4:45 AM
I sort of concur. Unless your cousin can afford 9k or more in damage repair, and can cover a liability claim out of his ass pocket at the very minimum he should have liability insurance.
05-23-2006, 5:51 AM
if i understood correctly, it's the complete lower end. he said that there was no transom damage. this outdrive.com might just be what we're looking for, thanks george. as for the no insurance attack team, he's asking himself the same question right now. however, in this area, i have yet to find somebody that does have insurance. i have it and i tell everyone about ski-safe but when people have a boat paid for, or an old wreck, they usually don't have insurance. "it's all fun and games until someone loses an eye." mama says.
05-23-2006, 6:18 AM
"however, in this area, i have yet to find somebody that does have insurance. i have it and i tell everyone about ski-safe but when people have a boat paid for, or an old wreck, they usually don't have insurance." According to you profile, I see your close to the sabine river? I'm guessing the majority of the people are from Louisianna on the Lake. If so , I can understand a stmt like this Good luck with your repair. (Message edited by acurtis_ttu on May 23, 2006)
05-23-2006, 6:23 AM
Those outdrives are easy to swap too. Basically, shift the drive in the full forward, unbolt the 6 bolts that hold the upper and lower unit on, and slide it off. Be sure to remember the Shift the drive into "full forword" -- That'll save you hours...days... of frustration. (Or at least this is how it was on the pre Alpha-one Mercruiser drives)
05-23-2006, 7:15 AM
How do you know he doesn't have liability? You people are quick to jump on people without knowing much about the guy.
05-23-2006, 8:44 AM
it seems that mr. adam curtis has a good read on the insurance subject. i looked at the estimate. $6300 for the Gimbal housing assembly (out-drive) 22 hr. @ $76 per hour = $1672 various taxes puts it at $9400. outdrives.com sells it for $3250 new. and it sounds like the 22hrs is a crock also. that estimate sounds like a busy dealer not even caring to me.
05-23-2006, 8:55 AM
That's ridiculously high. It's been a while since I've worked on one, but IIRC the gimbal housing isn't really the outdrive, just the 2-axis swivel mechanism. I bet if you really look, it just needs the yoke and/or transom plate thing. I removed, rebuilt (bellows, switches, bushings, etc), and reinstalled that whole assembly in about 12 hrs, the first time I'd ever worked on an outdrive.
05-23-2006, 8:58 AM
I've pulled a few outdrives if it's remove and replace - no fiberglass damage - no change to the mounting hardware it can be done in 3 - 4 hours max. If the gimbal housing is busted I would be concerned about the transom, fiberglass, and gelcoat damage. If the transom mount has to be replaced the engine has to be removed and alignment is critical on the install.
05-23-2006, 9:57 AM
True, I did have to get mine aligned by the shop - about $100. Definitely look the transom over, but it wouldn't surprise me if the yoke or something could break without damaging the transom, though. They are just big aluminum castings.
05-23-2006, 10:16 AM
I thought one of the selling point of outdrive boats is that they are suppose to have a break away coupler inside. The reason they say is to allow the coupler to break and the lower unit gets swung up, but, no major damage is suppose to occur. Has anyone heard about this before or were the salesmen blowing crap?
05-23-2006, 10:26 AM
Hit anything hard enough, you'll do damage beyond what is supposed to "shear" off. I don't think?? the driver was idling over a stump. Salesman is probably not wrong, but he's not telling you everything.
05-23-2006, 6:24 PM
i talked to the dealership today, the guy very politely told me that they simply did not have time to experiment w/ what may or may not be broken, that they only have time to change parts. so that was a change of everything from the transom to the foot. they were very happy that i came and got it. tomorrow i'm taking it to a smaller shop that told me that $9000 was ridiculous. the driver was not idling, he was traveling, when he hit the stump, probably around 20mph.
05-23-2006, 6:28 PM
well its going to be more then just an outdrive, i bet he has problems with his transom assembly and i bet he needs a engine coupler, i can see 9k real fast in parts
05-23-2006, 8:48 PM
dwayne, I have a possible solution for you! I'll pm you!
05-23-2006, 9:07 PM
Should be able to find an Alpha somewhere cheap, the go fast boys are always replacing them with Bravos. Check the classifieds in HotBoat mag (or ebay)
05-23-2006, 9:13 PM
"There's my 2 cents, unlike others on here i will not be recommending a place to get the boat fixed." Thank God for that. BTW, the examples you gave in your post still would not cover HIS boat if he had only liability insurance, which you are recommending. He would still need a shop to fix his boat. Get used to the idea that as long as insurance is not required, not everyone will have it. Good luck on the outdrive fix, I for one don't wish that one anyone, insurance or not. Good job not getting ripped off for 9K!
05-23-2006, 10:00 PM
Dwayne, There's a guy on the south end of toledo, louisiana side, rebuilds uppers and lowers. He's done a few for me over the years(TORO Service Center). There is also a company out of Florida that is producing MERC outdrives brand new for half the cost of OEM. You should be able to replace entire outdrive for $2000 tops (if you can turn a wrench).
05-23-2006, 10:36 PM
hotboat.com forums section
05-24-2006, 4:43 AM
I had a Merc 4.3 V6 and replaced my outdrive about 8 years ago. I think it cost a little over $2,000 but I have insurance.
05-24-2006, 7:56 AM
quote:well its going to be more then just an outdrive, i bet he has problems with his transom assembly and i bet he needs a engine coupler, i can see 9k real fast in parts
I bet you can! (see occupation in profile)
05-24-2006, 11:03 AM
05-24-2006, 2:27 PM
dougrussellmarine.com.....they have tons of models and years to choose from....should be less than 3k...
05-24-2006, 9:09 PM
wow, you guys have been way more than helpful, i can't thank y'all enough. here's the deal; i took the boat to a smaller shop in nacogdoches, tx. the service manager told us that to do a proper estimate that he would have to charge us for a couple of hours. great!!! that's all we were looking for in the first place, he said 22 hrs. was ridiculous that he could change everything listed and rebuild the engine in that time. so hopefully by the weekend we'll have a better idea of what the cost will be. this thing is still wide open though, we may be shopping for parts after the weekend. i'll keep in touch.
05-25-2006, 4:59 AM
Good luck, Dayne. Keep us posted.
