Old     (gekkorider08)      Join Date: May 2015       05-16-2015, 6:31 AM Reply
I have a 2005 gecko GTS-20 and im looking to change the wake depth but not sure how. anyone have any info it would be greatly appreciated.
Old     (gekkorider08)      Join Date: May 2015       05-16-2015, 6:34 AM Reply
it doesn't have the electronic adjuster on it by the way
Old     (sidekicknicholas)      Join Date: Mar 2007       05-16-2015, 6:44 AM Reply
As in make the wake bigger?
... if so, you're not going to get a ton out of that boat. ... its a designed ski boat, its purpose is to make the wake as small as possible. Your best / only option is adding fat-sacs / ballast to the boat, but even then you probably won't see a huge improvement. Maybe 1,500 extra lbs of ballast (1000 rear and 500 front) would be a start.
Old     (gekkorider08)      Join Date: May 2015       05-16-2015, 6:50 AM Reply
yea, there are adjustments that can be made just don't know how. didn't know if anyone else on here has tried the same.
its got a hell of a wake on it already just trying to learn the full capabilities of it
Old     (sidekicknicholas)      Join Date: Mar 2007       05-16-2015, 7:37 AM Reply
What you say adjustments, do you mean like a wakeplate?... if so a photo will help.... even with a wakeplate adding ballast will be the biggest help.
...just so I'm clear, we're both talking about this boat (give or take)
If so, I'm a little hesitant to believe its got a "hell of a wake" .... it was 100% designed to not have a "hell of a wake", literately designers tried to make this boat make as small a wake as possible..... if I'm wrong, kudos and enjoy!
Old     (gekkorider08)      Join Date: May 2015       05-16-2015, 8:25 AM Reply
are sumo sac ballasts better and/or more convenient than the fat sacs?
Old     (boardman74)      Join Date: Jul 2012       05-16-2015, 2:50 PM Reply
I would think you have to be pretty careful adding weight to a Gekko. The have extremely low (lowest of any inboard I know) freeboard in the rear. No way would I feel safe adding 1500 lbs to that boat. I'd add a 500 lb sac in the rear rear first and go from there.
I'm also confused about your term "adjustments"??? You are talking you want to make the wake bigger for wake boarding, correct?
Sumo sacs are just a another brand of ballast bag. No better no worse, Ford/ Chevy kind of thing.
Old     (gekkorider08)      Join Date: May 2015       05-18-2015, 4:46 PM Reply
yea why would you think I would start with 1500 lbs.?? im doing a 750 SUMO in the back seat with only the driver it would be perfect. and yes the adjustments would be for wake boarding but its a ski boat so I wont get what I need out of it without the sacs.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       05-19-2015, 8:48 PM Reply
Nauti 2001 was designed as a ski boat too. Start with that 600 and add more as you need! Have fun!
