Old     (WakeMark)      Join Date: Jan 2014       01-15-2014, 11:58 PM Reply
Hello everyone!!
I have just bought online a pair of 2014 parks boots and I have one question about the fitting. I use US9 shoe size so I have bought a US9 boot size. How to know if they fit ok? I have tried them aroud my house and they feel as follows (I have still not had the chance to try them in my usual cable-park):
with my legs without flexing I touch with my toes the end of the liner, and when flexing my legs (knees over my feet) I can barely touch the end of the liner with my toes, just only a bit almost nothing. My heels feel really good not loose. IS THIS FITTING OK???
Thank you so much in advance and sorry about my english, I am from Europe.
Old     (dezul)      Join Date: Jul 2012       01-16-2014, 2:18 AM Reply
The fitting sounds perfect. They will loosen up when you get them in the water. Don't forget to heat form the linear. Enjoy!
Old     (Kane)      Join Date: Mar 2010       01-16-2014, 2:58 AM Reply
Sopunds fine, I found Ronix bindings fit true to size unlike LF.
Old     (WakeMark)      Join Date: Jan 2014       01-16-2014, 7:57 AM Reply
Thak you very much, I was wondering if touching the end of the liner with my toes when my legs are not flexed was normal.
Old     (boardjnky4)      Join Date: Dec 2011       01-16-2014, 8:16 AM Reply
Here is how I always determine fit.
1. Put the boot on and lace it up. When standing at rest, your toes should barely be touching the front of the boot.
2. Lean forward hard against the boot. Your toes should move away from the front of the boot and not touch AT ALL.
3. Lean back against the boot, your toes should now be hitting the front of the boot.
Once the above is satisfied, you've got the correct fit.
Old     (behindtheboat)      Join Date: Aug 2006       01-16-2014, 9:03 AM Reply
Agree, sounds perfect. They will pack out (get a little larger inside), as well as form to your feet. I think it's better to fit like that than have any additional room than that.
