Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 23, 2005
Old     (openwydr)      Join Date: Aug 2004       07-17-2005, 6:33 AM Reply
I have WB pro 6.0
The PP was working and now all of the sudden it does not work. I checked everything and have discovered that the servo motor is not keeping tension on the throttle. ( it is not rewinding the string....) Any hints on how to remedy this?
Thanks
SB
Old     (pcm2a)      Join Date: Feb 2005       07-17-2005, 10:34 AM Reply
My '00 Tige did that this year and my local shop had to replace the PP servo motor. Cost about $60 including labor. The part was only $30 and looking at it I think anyone could do it themselves.
Old    upupnaway            07-17-2005, 11:46 AM Reply
Does the servo try to wind, or just not move at all?
My set screw on the knob shook loose once, and that is what the string is attached to. The post would turn, but the knob and string would not.
Old     (openwydr)      Join Date: Aug 2004       07-17-2005, 4:43 PM Reply
Set Screw is still in place. All was working fine until I had the boat go in for reg maintenance, then no work. Techs said they did not mess with the PP.
Any thoughts
Old     (tlb)      Join Date: Feb 2003       07-17-2005, 6:18 PM Reply
This happens on mine every so often. There is a way to reset it. Turn the motor off. Twist the servo knob all the way clockwise until it's tight. Then back it off 1/2 turn. Go back and key the ignition on and you should see it self tighten and then click a few times.
If that dosen't fix it check fuses then call PP.
Good luck
