Old     (BobGriff)      Join Date: Feb 2014       02-26-2014, 2:20 PM Reply
Have a '06 Sanger V210 and looking at getting a stereo installed. Looking for something like Wetsounds WS420 instead of normal HU as only really use ipod etc and starting on a budget for simple cabin set up (4 speakers and sub). May well hook the tower in later years. I have nothing in there at all right now and there has never been anything installed prior, so no speaker holes etc anywhere! Single battery. Was thinking of a self install, I can easily buy the equipment but any thoughts, ideas or suggestions?
Old     (Dmac420sj)      Join Date: Mar 2012       02-26-2014, 3:02 PM Reply
It's easy. Just gotta get up and do it. Lol doesn't really help but wanted to give you some confidence.
Old     (Dmac420sj)      Join Date: Mar 2012       02-26-2014, 3:03 PM Reply
Your post isn't really clear on what you want advice on?
Old     (trayson)      Join Date: May 2013 Location: Vancouver WA       02-26-2014, 3:50 PM Reply
1) Buy speakers
2) buy 4 channel amp and sub amp, or 5 channel amp.
3) buy sub
4) Make or buy sub box (if you're gonna buy there are some inexpensive boxes with bedliner coatings you can get for well under a hundred)
5) get speaker wire and RCA's (or a couple amp wiring kits)
6) cut holes, install speakers, run all wiring
7) Rock out with your C*** Out!!!
Old     (BobGriff)      Join Date: Feb 2014       02-26-2014, 3:50 PM Reply
Placing of speakers, recommendations, wiring, drilling out the fiberglass for speakers etc? I was anticipating that someone on here may have installed from scratch. Paying $120 per hour as I was quoted seems a bit much for right now.
Old     (Dmac420sj)      Join Date: Mar 2012       02-26-2014, 4:06 PM Reply
I did my entire v210 last year my self mine is a 2003 which I think has a different tub. But it's all the same ****. Your gonna need a drill,bits ,hole saw,string,I soldered all my speakers and shrink wrapped the connection. I mean if you have basic mechanical skills once you get I. There you will figure it all out.
Old     (ccripps)      Join Date: Oct 2003       02-26-2014, 4:11 PM Reply
if you are in So Cal come on by I have 08 V210 w/ Kenwood deck with iPod control
4-kicker 6.5" installed in Boat, 1 JL 12" Sub in custom box in front of the Driver and 4 6"x9" in wetbox on the Tower and 2 amps a
Kenwood 600 watt 4ch.amp and a JL 300 watt 4ch.amp, Dual Battery. a Baby System in comparison to others on this site but very easy to install
Old     (Dmac420sj)      Join Date: Mar 2012       02-26-2014, 4:20 PM Reply
Very easy
Old     (bwake)      Join Date: Sep 2009       02-28-2014, 1:30 AM Reply
Check out fusion marine head decks. Have one and reccomend
