We were at a lake all week last week and while the boat sat on the water it took on water. The bilge would automatically come on during the night. The Shaft seal is brand new just got replaced and before we left it was re-tightened after installed. What is the normal water intake on these direct drive boats? Is this normal? I need some help cause the dealer is saying its normal and it doesn't seem normal to me.
I've never had that happen in several years so to say that's normal to me would be a misnomer. I don't feel as though you should be getting enough through the shaft seal to kick on the auto bilge.
yea when the engine is running it is misting out the seal kind of like a shower head. Its way to much water in my opinion. But the crazy thing is when it;s sitting still that's the part we can't figure out.
I had the same problem but it was the through bolts on the swim platform that were leaking. You also might check your exhaust hoses and mufflers, raw water intake, and any intakes for ballast
Sounds like they did not replace your shaft packing properly... Should not be "misting" around the shaft packing. Should just have the slight drip people mentioned. Probably getting all your excess water around that packing....
I know you got it posted in the right section now, but next time, try not to post two threads. Not only does it clutter up the forum, but it's hard to keep track of the discussion.
