Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through July 23, 2005
Old    boarddude            07-19-2005, 2:09 PM Reply
I have a boat trailor in which one tire is shot and need to replace. The problem is they no longer make the Hanook optima sport tire. A replacement is needed. Can you adjust the torsion cam arm (holding the wheel) to accomodate the newer higher profile tires? If so, can you just change the angle of the cam arm down? Will this make problems in spring tension or change the dynamics? ANY INFO WOULD BE HELPFULL. Thanks.
Old     (domin8)      Join Date: Mar 2004       07-20-2005, 7:53 PM Reply
Did you try the trailer mfg. ? How much differance is there in the tire dia. ?
