When I went to winterize my boat (it has a merc 5.7 350) a few weeks ago, very little water drained out of one engine block drain, and the other side didn't drain anything. I ran about 15 gallons of antifreeze through it hooked directly to the water intake line. I then drained everything. When I opened up the plugs on the block, some antifreeze came out of the passenger side at a very slow rate, but none came out of the driver's side. I put a piece of wire up in the block, and that increased my flow a bit on the one side. Yesterday, I went back with a piece of sturdier wire and a small screw driver, and I was able to get one side completely open. I dumped antifreeze down the thermostat opening, and it came streaming out the plug opening like it's supposed to. Still nothing coming out the other side. I think part of the problem is the plug is on a fitting underneath a knock sensor. Thus, it's hard to get the hanger in there as far. If I pull the knock sensor, will water drain from there? Also, how is the cooling system settup? I know water goes in from the top after going through the thermostat. Other than right there, is there any place where both sides of the block are connected?
