Old     (packrat)      Join Date: Mar 2005       07-07-2006, 11:25 AM Reply
I have a 2001 X-10 Mastercraft with the wakeboard pro perfect pass. I was wondering if anyone has played around with the KW Pull Characteristics settings. I have about 1500 Lbs ballast in the boat when surfing with a 4 blade prop. Should I be around 80 or 90 on the setting or higher/lower? I do get some surging when using the MPH setting at 10.0mpn. Thanks
Old     (amonteroman)      Join Date: Aug 2005       07-07-2006, 1:31 PM Reply
I have mine set at KDW=180,NN=80,this is with a 4 blade prop and 1400 pounds of ballast,PP in wakeboard mode. These settings work well with wakeboarding as well. No surging and speed stays within 1/2 mile per hour up or down.
