Just had another thought, from what I can see in the photos it looks like you have a Mando alternator so why don't you just put a bigger Mando alternator on it? The Mando alternators don't have a 2 pin plug but have screw on terminal rings so if I'm correct someone has already moded the wiring loom so that they can be fitted. The other reason is that I'm not sure if the pulley on the Mando will fit the shaft on the Delco as I have never checked, I do know the shaft on the 70a Delco is the same as the 95a Delco.
