Old     (robertsjut)      Join Date: Jul 2009       12-28-2015, 12:05 PM Reply
Hey Guys,
I'm located about 1.5hr south of the Portland Area and looking for a place to get a prop repaired.
Thanks in advance.
Old     (tyler97217)      Join Date: Aug 2004       12-28-2015, 1:39 PM Reply
There are several places up here in PDX. Otherwise maybe just go to any local dealer. They usually have a program to send them in for repair and get it back to you a week later.
Old     (h20king)      Join Date: Dec 2009       12-28-2015, 2:30 PM Reply
Yep what^^^^he said go by your closest dealer and have them send it in
Old     (spencerwm)      Join Date: Feb 2009       12-28-2015, 4:33 PM Reply
Rocky at Independent Marine Propeller is the best in Portland. They will have your prop looking brand new.
http://imppdx.com/
Old     (AZVLX)      Join Date: Sep 2012       01-13-2016, 10:02 AM Reply
I have a prop for $350, good as new, if you're looking for an extra
Old     (denverd1)      Join Date: May 2004 Location: Tyler       01-13-2016, 12:02 PM Reply
Im saving about $50 each time I send it in myself. went through 3 last year..... don't go exploring in an inboard
Old     (camassanger)      Join Date: Oct 2009       01-13-2016, 12:28 PM Reply
I've had Sheffield Marine on Marine drive repair two props. They both make noise (squeek) while underway now... not cool. I tolerated it all last season, but need to get them fixed elsewhere because the squeeking is no bueno
Old     (tyler97217)      Join Date: Aug 2004       01-13-2016, 10:50 PM Reply
squeek and prop don't sound like they should be related...?
Old     (TomH)      Join Date: Jan 2014       01-14-2016, 7:40 AM Reply
Maybe the 'squeak' he's talking about is prop-sing, which would be high pitched whine/whistle. If the prop shop left the back of your prop blades sharpened to a point, you'll almost surely get that at idle speeds, and usually goes away as speed increases. I had one prop come back from a repair that way and had to file the back edges square to get rid of the sing, so I've quit using that shop. It came back perfect from the next shop I used (propmd).
But yea, if you truly have a squeak, I wouldn't be necessarily looking at the prop.
Old    r33pwrd            01-14-2016, 8:05 AM Reply
Up here in seattle it was the same price from bakes as sending it in directly I think it was 200 bucks.
Old     (camassanger)      Join Date: Oct 2009       01-15-2016, 7:42 AM Reply
Tom, you are exactly right. It is prop-sing. I had the shaft and packing inspected and both are perfect. I knew that I hadnt damaged it, but wanted to be sure. The singing does go away just after idle speed. Thanks for the tip on squaring up the backs of the blades - I hadnt heard this and will definitely try it.
Old     (newty)      Join Date: May 2005       01-16-2016, 1:09 PM Reply
I've used Sheffield for years and never had an issue. In Fact I've had them fix props from independent that had major issues after being "repaired".
FYI the dealer is going to pin $50 (plus or minus) to the repair price.
Old     (VinnyQH)      Join Date: Jul 2011       01-19-2016, 10:48 AM Reply
I used acme prop repair in clackamas. They did good work on my 537. Btw I also have a 1235 for sale or trade for a another 537, it was too aggressive for what I need.
(503) 655-9013
11497 SE Mel-Brook Way, Clackamas, OR 97015
Old     (spencerwm)      Join Date: Feb 2009       01-19-2016, 11:40 AM Reply
(503) 655-9013
Vinny, do you mean Ampro? I used them when they were right across the street from the old Wakeside.com warehouse. They did good work too. They off of Hwy 212 which is convenient if you are in that area.
Old     (newty)      Join Date: May 2005       01-20-2016, 3:37 AM Reply
(503) 655-9013
What are you asking for the 1235?
Old     (BlazeSr)      Join Date: Dec 2012       01-31-2016, 8:55 PM Reply
I dropped two off at Sheffield last week. $145 a piece + 10% off for bringing in two. I'll let you know how they turn out.
I called acme direct and they recommended them.
