place a washer behind the pulley (reinstall with a washer in there) so that you move the pulley away from the engine by the thickness of the washer. Should get the pulley closer to true alignment w/ the belt. Merc tensioners are known for issues, including smoking a belt causing overheat. (Message edited by denverd1 on August 21, 2009)
