Tracktor- Sorry for the late response, I have been driving to and from Dallas.. Tim is right on the money, (thanks Tim!). You probably have the gain set too high for the tower system and you are sending a clipped signal to the speakers. the tweeters are poly-switch protected, and your description exactly describes the switch going on and off. You need to take a look at your total system gain. Tim and I have posted here and there the proper method for getting all your gains set properly, and a little searching will probably turn up the proper procedure. Regardless, it sounds like you at least need to turn the tower amp gains down. If you can't find the gain setting tutorials, post back here, and I can help dig for them. Tim, again, thanks for hopping in during my absence! Take care, and let me know if you have any additional questions! Phil Kicker
