Originally Posted by bass10after
Forgive me if this sounds crazy(I'm a few coronas in) but why not run the y right off the pump and fill and drain them both at the same time?seems like filling one tank then going to the other would create more of a problem when draining
I have spent multiple corona's considering the design so no need for forgiveness.
my current plan is PUMP to Y valve then to either bag or tank.
the only real reason for this is so as I can fill TANK and then separately BAG - yes it makes it a two step process
I need to be able to isolate the bag as I will only use when surfing.
another option is
- PUMP to plain Y splitter (not a Y valve)
- Y to tank &
- Y bag with an inline valve (so I can shut off bag)
the only problem I saw with this is that I might fill one and then have water coming out the overflow when trying to fill the other?
that said, having looked a bit more carefully at the venting I think it should be ok as the top of the tank is higher than the bag will be so the bag should fill first?
