Old     (jagermeister)      Join Date: Sep 2007       10-30-2010, 8:27 PM Reply
I picked up an 07 Xstar. The oil was off the stick so we added a quart and a half to it prior to testing the boat.. Ran fine.. all temps and pressure good.. But the check engine would display in the window occationally.. I'd hit the display switch and it would go away for an hour or so.. Is this a latched fault that has to be cleared or do I have other probs that I don't know about yet?
Thanks Guys...
Old     (imscarlet)      Join Date: Mar 2008       10-31-2010, 12:39 PM Reply
Rather you than me re picking up a boat with next to no oil in the engine! I would have to say connect it to the diags as the ECU will remember certain faults such as no oil pressure especially if its gone into limp mode at some stage. Having said that it could be caused by another completely unrelated issue which maybe why you haven't had a response to your question yet as its pretty generic, dealer that services any boat with an Indmar engine should be able to retrieve the code i.e. Skiers Choice, Mal, MasterCraft... if its specific to Indmar engines.
BTW I would have thought this is basic stuff that your "maintenance service" as advertised on your web site should be able to answer! Anyway best of luck with this one....
