The MC brackets fit the Mastercraft and Supreme. So same bracket. In order to fit 4 REV 10. You would use the MC adapter on the sides and would need to use a clamp mount to the pipe for upper mount. You would move it over away from the welded on upper mount. You could always mount a RGB led light at the welded on mount and make use of that mount. We are always working on new adapters but on some boats like this, there is no plans for an additional adapter.
Tim
Wet Sounds
