Old     (saae4)      Join Date: Feb 2014       02-28-2014, 4:13 PM Reply
I'm getting an x25 and it has dual batteries and this distribution box. Our old boat had none of this (or a center drain plug for that matter..just transom plug). Can someone point me to info on using this distribution during summer boating/storage and winter storage?
Old     (DavidAnalog)      Join Date: Sep 2013       02-28-2014, 5:06 PM Reply
That's unusual because it looks like they combined a BEP Marine voltage sensing relay with a Blue Sea manual switch.
Here is the best guess for operation without seeing the actual model numbers.
Use the switch in the 'On' position whenever the boat is off the trailer which will allow the DVSR to automatically isolate the two batteries when voltage drops and combine the two batteries when voltage has returned to normal. This way the starting battery will always be held in reserve for dependable starting after a stay at rest and using your electronics.
Turn the switch to 'Off' when the boat is in storage.
Use 'Combine' in an emergency where you need to manually force the two batteries to parallel.
