Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 09, 2007
Old     (buster99)      Join Date: Feb 2007       02-08-2007, 4:09 AM Reply
I own a Session 22XI and have had repeated problems with broken prop shafts.
I snapped the original, and the replacement one only lasted 2 weeks.
Is this a common problem, and is there a better solution?
Any help appreciated.
Old     (rallyart)      Join Date: Nov 2006       02-08-2007, 8:45 AM Reply
It shouldn't be a problem. I assume your prop is OK and is not hitting anything. You could have a problem with sever out of balance but you would feel that easily. You probably have an alignment problem that's putting a side load onto the shaft. If that's the case, you need to look at the motor mounts or a manufacturing problem. It does not take much of a misalignment to cause a failure. Take the broken shaft to a metalurgist if you need to as they may be able to look and tell you how the failure progressed.
Good luck.
Old     (polkaking27)      Join Date: Feb 2005       02-08-2007, 4:33 PM Reply
Was it your prop shaft that broke, or could it have been the plate that mounts to the v-drive. I had a problem with the plate, I can give you more info on that if you need it.
