Old     (cal2vin)      Join Date: Jun 2010       11-05-2017, 7:53 PM Reply
In the video wetsounds had up from SEMA, I heard them say SD2500 amp powering the 15 XXX's. Anyone have any information on this amp? Release date or specs. Wondering if it will do 2500 at 2 ohm since that would be the configuration for 2 XXX subs.
Old     (jonyb)      Join Date: Nov 2008       11-05-2017, 8:53 PM Reply
Soon.
The amps will be updated, should be first quarter.
Old     (chpthril)      Join Date: Oct 2007       11-06-2017, 6:35 AM Reply
im excited to see a high power Wet Sounds mono amp. Been a long time coming since the retirement of the Syn-1.
Old     (corerider)      Join Date: May 2008       11-06-2017, 6:47 AM Reply
The way I understood them talk each XXX-15 had it's own SD2500 amp, but I may have misheard the walk-through. Also sounded like they had an SD6 running 3 Rev10s... so 585 watts per pod basically. I'm sure the gains were turned down some, but I bet that boat screams!
Old     (cal2vin)      Join Date: Jun 2010       11-06-2017, 6:49 AM Reply
Very interested in that amp. Hopefully it has a subsonic filter too. Their answer for XXX power now is the SD2 which does not have a subsonic
Old     (chpthril)      Join Date: Oct 2007       11-06-2017, 7:42 AM Reply
Cal,
The new Syn-DX2.3HP has subsonic.
Old     (cal2vin)      Join Date: Jun 2010       11-06-2017, 7:59 AM Reply
Ooo cool. Is there a benefit of going with the sd2 over the dx2,3hp? Rated at same power. SD2 supposed to be better quality
Old     (chpthril)      Join Date: Oct 2007       11-06-2017, 8:43 AM Reply
In the case of using for a woofer amp, i dont know of one. the SD series was released as a top of the line, high output marine amp. Awesome power and very robust amps. The new Syn-DX series shares a good bit of what the SD series is build on. The new Syn-DX2.3HP is in not a hopped up Syn-DX2. The DX2.3HP is about the size of the 6 chnl DX6 so its like 2x the size and weight of the DX2.
Old     (jonyb)      Join Date: Nov 2008       11-11-2017, 4:29 PM Reply
I’ve been riding Tim for 2years abiout the sub amp situation
