Go Back   WakeWorld > >> Boats, Accessories & Tow Vehicles Archive > Archive through February 09, 2007
Old     (dizzyj)      Join Date: Jul 2003       02-09-2007, 9:04 AM Reply
I'm going to pull my engine and tranny on my 2000 xstar to replace the damper plate. right now, it sounds like a box of rocks.
Ive got the predator engine with the combined hurth vdrive/tranny. I'm looking for anythything to look out for or any advice.
Also, what else should I do to the engine/tranny while I have it pulled. I've been told I might as well drain the tranny really good, and replace the seal.
So far, I've been told that I need to:
-remove the back seats
-remove the walls
-remove the engine cover
-pull the engine/transmission as one unit.
-have a shop realign the propshaft when done.
anything else?
Old     (curtisco24)      Join Date: Dec 2005       02-09-2007, 10:29 AM Reply
Go ahead and give it a tuneup while its out, and maybe grease the starter while its easy to get to.
Old     (malibuboarder75)      Join Date: Jan 2004       02-09-2007, 10:40 AM Reply
How much does a realign job go for?
Old     (wakescene)      Join Date: Feb 2001       02-09-2007, 10:42 AM Reply
Tighten the strut bolts and steering assembly while the engine is out...
Why are you pulling the engine?
Old     (rich_g)      Join Date: May 2003       02-09-2007, 11:30 AM Reply
here is a link that might be helpful if you don't have the tech manual:
http://www.simplicity-marine.com/hurth630.htm
also, when you pull the back seat, place some cardboard in between the seat and the side to protect the vinyl side panels. I pulled all the same stuff to do some interior work and it was kind of a squeeze to get the seat out.
Old     (dizzyj)      Join Date: Jul 2003       02-09-2007, 11:30 AM Reply
realing is ~100. I've done it before, but its pretty much artwork.
I'd be removing the engine and trany/vdrive, because I was told that is the easiest way to get to the tranny/dampner plate, instead of trying to do it in the boat.
so, for tunup, plugs, wires, etc?
