This is a solution to a problem that doesn't exist, and it will create other problems. I don't trust cheap plastic parts in critical applications, nor do I trust a single o-ring for a drain plug. That plug design will get clogged up with junk eventually and not close, or bilge gunk will wear the plastic and oring resulting in sloppy fit and leaks after some time. When it breaks or wears out, I'd be looking at at least 24 hours to get back on the water to set a new garboard drain which only costs a few bucks and just plain works.
