Old     (BigBen)      Join Date: Aug 2014       06-17-2015, 9:06 AM Reply
Looking for a new ride this spring/early summer. I think a Sanger v210 is in order!! Just curious what you all do for winter storage? My house has a double garage that is 20'7" tip to tip. The boat will fit in at an angle but this poses a problem! The significant other likes her garage parking when it's cold out! I am sure I can swing it being in the garage during months it's being used but NOT during the winter! No extra room outside my house to keep it in winter either! What to do?
Ben
Old     (on_wi)      Join Date: Feb 2013       06-17-2015, 9:27 AM Reply
I pay for heated indoor storage. If you winterize properly you should be fine with unheated. $400 based on a 20' length.
Old     (denverd1)      Join Date: May 2004 Location: Tyler       06-17-2015, 10:53 AM Reply
folding tongue and removable swimstep
you'll still need a slight angle, but shouldn't have to put it in there sideways
measure your height as well. brought my v230 home to learn I needed to modify the tower front legs to make it fit folded down.
Old     (on_wi)      Join Date: Feb 2013       06-17-2015, 11:08 AM Reply
As Nacho said you may be able to get your boat in straight if you remove the swim platform and swing the tongue in. My garage is 20'8" in total and so is the boat (Axis A20). I put it in with a slight angle and the door can close.
But, I would only do that for a long term storage - like winter - because the platform is not something I want to mess with when I want to get on the water. Good luck.
Old     (ksunet)      Join Date: May 2015       06-17-2015, 2:20 PM Reply
I store my boat in the caves in kc. It stays at 70 degrees year round. Not sure if you have this option but it is very affordable.
Old     (jdiaz78)      Join Date: Sep 2014       06-18-2015, 5:42 AM Reply
Are you able to just store your boat there for the winter months or do they make you pay for the entire year? Also, do you winterize your boat since it never sees anything close to freezing temps? BTW, I'm also from KC.
