Old     (y49sides)      Join Date: Aug 2007       11-03-2009, 6:08 PM Reply
Recent took my 06' stock prop off to have it repaired (small dents and a bit of a vibration). I believe it said 14.25x17.
I usually have about 8-12 riders but I don't usually fill the ballast. (beginner and novice rider mostly).
Also do a lot of surfing.
Is there a better size prop that I should be looking at or does MC do a great job in the R&R?
I just don't want to go out and buy a different one that will only give me a minimal change.
Old                11-04-2009, 3:48 AM Reply
What motor is in the boat? Re-check the size of the prop as we do not make a 14.25 X 17.
Old     (cccbuilders)      Join Date: Jun 2007       11-04-2009, 5:35 AM Reply
I have a 06 x30 with 350mcx. I re-propped with an 4.25x14.5. Depending what prop you currently have, this prop will get up on plane easily with full ballast and 8 - 10 people. I believe my stock prop was 13 inch. Night and day improvement.
Old     (y49sides)      Join Date: Aug 2007       11-04-2009, 7:35 AM Reply
You are probably right about it being a 13 and not a 17. It's currently at the shop and couldn't remember. Thanks.
What brand would be recommended?
Old                11-04-2009, 10:46 AM Reply
Would say it is a 13.7 X 17. Our OJ PROPS 14.25 X 14 or 14.25 X 14.5 would be a big improvement.
Old     (y49sides)      Join Date: Aug 2007       11-04-2009, 2:16 PM Reply
Eric. just got the call that the prop was ready for pick up. It is a 13.7 x 17.
I have done some research on the 14.25 x 14.50. I have seen a few different cup sizes. Which would fit this application?
Are you a dealer? Location? Any in stock?
Old                11-05-2009, 3:40 AM Reply
The standard cup for the prop we supply Master Craft is .120. I am the builder of the prop and located in Loudon, Tn. The prop is in stock.
