WakeWorld
WakeWorld (http://www.wakeworld.com/forum/index.php)
-   Boats, Accessories & Tow Vehicles (http://www.wakeworld.com/forum/forumdisplay.php?f=3183)
-   -   Any reason I shouldnt put my amp here?? (http://www.wakeworld.com/forum/showthread.php?t=809340)
Ccamp2 05-30-2020 2:07 AM
Hey everyone.. I am planning on mounting my Amplifier, amp fuse, blue seas switch and relay, RGB controller and an led light to a panel then mounting it here.. The engine bay is Hugeeeee. anything I should be worried about with heat??https://uploads.tapatalk-cdn.com/202...f5eb614f33.jpg
hal2814 05-30-2020 2:34 AM
If it’s not too hot for the battery, it’s probably not too hot for an amp. You could always measure temps in the compartment to make sure. My engine bay gets dirty over time. You may get a little soot on your equipment over time but that would be minimal. More concerning to me would be a leak in the coolant system. If something like a coolant hose fails, it’s going to spray water all over that compartment. I’ve had that happen. It’s not fun. I really don’t even like the battery being in the engine compartment. I would be very uncomfortable having an amp and light controller in there. Keep in mind this is just my opinion and it’s based on a failure I’ve personally had happen but is admittedly pretty rare.
ottog1979 05-30-2020 5:40 AM
Second this.
denverd1 06-03-2020 4:47 AM
or if you take on a little water, it will end up in the bilge. enough of it, your belt will be running in water which will spray it everywhere.
also heat really kills the performance of an amp. I think there are better places to put it.
