Subwoofer Enclosure materials
Advice needed for the following products for a sub box?
1) http://www.menards.com/main/building...30-c-13338.htm 2) http://www.menards.com/main/building...95-c-13332.htm 3) http://www.homedepot.com/p/T-G-Drypl...9058/202522977 Also, is 1" MDF that much better? |
Birch is good to use and lighter than MDF. Resin coat it and it will outlast you owning it.
^^^ like he said birth. i wouldn't use mdf in a boat for some reason even with resin it still gets moisture and falls apart.
I build all of mine out of Azec. It's basically indestructible, totally impervious to the elements, and a joy to screw together - never spits, etc.
Which would be stronger? |
Im thinking about some HDPE. Its not cheap, but I don't to rebuild it.
