02 SAN 210 ballast system upgrade options
I recently sold my 2000 Super Air Nautique and picked up an 02. In my old boat I just ripped out the entire factory ballast system and installed a reversible system with jabsco pumps. Although I liked the system, I don't know if I want to go that route again.
All I have is the two rear factory tanks. Is there anyway I can tweak the system so I can fill and drain each tank individually? And somehow get rid of the seacock handles that I have to manually open and close every time? I don't mind sticking to aerator pumps, I just want it to work like a normal aerator system. Make sense? Any help is appreciated. Thanks |
I did a full aerator system in mine two years ago. 2 750s in the rear, 650 in the locker. Fills in 5 minutes.
You just need dedicated pumps for fill and drain and some check valves on both. I have a detailed install on planetnautique if u search my name |
Three issues with aerator pumps that would make me consider reversible impeller pumps:
1) Aerator pumps will continue to fill while you are underway unless you incorporate a seacock at the inlet. 2) You need two pumps (fill and drain) verses one impeller pump. 3) Aerator pumps are not self-priming so you'll need to be underway to get the pumps to prime. Impeller pumps are self-priming. I'd keep the seacocks as a safety item should you want to leave your boat in the water for an extended period (i.e. weekend). This way you can shut them and not worry about a leak developing that could sink your boat. Seems to me if you are going to re-do your existing system, I'd go with a couple of impeller-based pumps. |
1. Not true. 2. True 3. Not true. I have one intake in the bottom of my boat that goes to a manifold with three aerator pumps on it. You just need a check valve on the fill lines to make sure they dont suck the bags dry while you are moving. I fill all my bags at once while sittig still. 2100lbs in 5 minutes. There are pros and cons to both. |
