fs or bs 360?
Hi all
I'm just wondering how easy is it to go from spinning bs to fs or more of interest really is what are the main differences in technique between the 2 (apart from the obvious spinning a different direction). I have been practicing bs 180's for a while and have been getting really consistent with them single wake and I have landed a few wake to wake. Getting a bit tired of just doing the same I thought why not just add another 180 on to the end of it for a bs 360 spin. I managed to land a single wake one last weekend after only a handful of attempts which got me very excited as that damn handle pass has taken me forever to get when doing the 180s. (PS my hint to add to the many already out there about bs 180s is to stay tall keeping the shoulders and head up, every time I do this I seem to land it, when I crouch or lean forward I tend to overcompensate for this when landing and slip out on the heels) I have read loads of the 360 posts on here and the vast majority seem to say start with a fs 360 so the question is should I go back to that or just continue with my bs 360? Or should I just go for both at the same time as the technique is similar? |
If you can do BS 1's the BS 3 is incredibly easy. Just start your spin a little bit earlier than you would for the 1 and it should come right around.
A friend of mine learned BS 3s before FS 3s and still prefers them. Agreed if you can do BS 180s, take it to 360. You'll have it in no time, the handle pass is the hard part.
Frontside 3 is easier for me. The BS 3 allows for a smaller margin of error, while the front 3 can be landed even if you miss the pop a little or spin a little early.
Ok in theory I would like to do both and I'm on my way to doing the bs 3 so is their anything different I should do when I go for the f's 3?
I find it tougher to stay on axis BS, especially going to 5's and 7's. I offset that by looking straight at the horizon as I'm spinning to keep me on axis. I also find I need to "throw" the FS spins more as I tend to take an aggressive cut and start my spins a little earlier.
I'm opposite ^. I tend to throw my backside spins earlier and pop and wait on FS spins so I don't go off axis and land on my face..
I also learned BS 3's before FS because once I had a solid backside 1 finishing is just a slight more spin. But the key for me was grabbing the handle with the trailing hand. Commit to reaching for it and you'll end up full spin no problem.
The front side is all about leading with your eyes/head. Try to get the chin over the shoulder and looking at the boat again and that's where you'll end up. |
