Clearing the wake with ease now. Video included.
Finally starting to get my timing and pop down. In my first video I was riding at 60ft I think and was casing or not clearing the wake. Now in the second video I'm back to 70 to 75ft clearing the wake with ease. I pulled the rope back in the last two videos to practice my backroll. I'm about 10 for 50 as far as landing them. Any help? From what I can see maybe I should let go with my back hand after I rotate.
http://youtu.be/w9zzOk388H4 http://youtu.be/pVBABryk8kc |
when you are just straight airing the wake, try to suck your back knee up a little bit. It will look better and make you land more even weighted.
https://www.youtube.com/watch?v=Ckkf840HZE4 This video helped me a ton. Those backrolls look pretty much perfect. Frank edit, also start trying grabs and 180s. They arent hard, but take time getting used too. |
Your absorbing a lot of the wake. Make sure you stand all the way tall to get a full pop. Don't focus on sucking your legs up as much.
I'm having the same problem you did with my 65' rope. I case the other wake almost every time. I was able to clear it once but I think all the stars aligned. Where you able to start clearing yours when you put the longer rope on?
Your absorbing in both videos. Leaning back a bit with a limp rear leg. Hold edge through wake more evenly balanced and you'll really pop. Especially at the speed your hitting it at. Man up kid!! Stiff legs=high air!!
Try getting your rope closer to your knees upon hitting the lip of the wake. Keeping the rope lower should help you get some more pop.
On your back roll you missed you tucked your head down too much. Remember look over your lead shoulder and up to initiate the spin. Then spot the horizon for your landing. You're looking down at the water. You tend to go where you look.
