2006 Sanger V210
Have a '06 Sanger V210 and looking at getting a stereo installed. Looking for something like Wetsounds WS420 instead of normal HU as only really use ipod etc and starting on a budget for simple cabin set up (4 speakers and sub). May well hook the tower in later years. I have nothing in there at all right now and there has never been anything installed prior, so no speaker holes etc anywhere! Single battery. Was thinking of a self install, I can easily buy the equipment but any thoughts, ideas or suggestions?
It's easy. Just gotta get up and do it. Lol doesn't really help but wanted to give you some confidence.
Your post isn't really clear on what you want advice on?
1) Buy speakers
2) buy 4 channel amp and sub amp, or 5 channel amp. 3) buy sub 4) Make or buy sub box (if you're gonna buy there are some inexpensive boxes with bedliner coatings you can get for well under a hundred) 5) get speaker wire and RCA's (or a couple amp wiring kits) 6) cut holes, install speakers, run all wiring 7) Rock out with your C*** Out!!! |
Placing of speakers, recommendations, wiring, drilling out the fiberglass for speakers etc? I was anticipating that someone on here may have installed from scratch. Paying $120 per hour as I was quoted seems a bit much for right now.
I did my entire v210 last year my self mine is a 2003 which I think has a different tub. But it's all the same ****. Your gonna need a drill,bits ,hole saw,string,I soldered all my speakers and shrink wrapped the connection. I mean if you have basic mechanical skills once you get I. There you will figure it all out.
if you are in So Cal come on by I have 08 V210 w/ Kenwood deck with iPod control
4-kicker 6.5" installed in Boat, 1 JL 12" Sub in custom box in front of the Driver and 4 6"x9" in wetbox on the Tower and 2 amps a Kenwood 600 watt 4ch.amp and a JL 300 watt 4ch.amp, Dual Battery. a Baby System in comparison to others on this site but very easy to install |
Very easy
Check out fusion marine head decks. Have one and reccomend
