Lifted truck drop hitch size
I just got a 07.5 duramax with 37" tire and maxed out 6" lift. I just sold the tire and now I'm going to run 35" and de-crank the lift to about a 4.5" lift and 3" blocks in the back. Do you think I could get away with a B&W 5" drop hitch.
http://www.ebay.com/itm/B-W-HITCHES-...34b42c&vxp=mtr |
yeah its a chevy the ride low to begin with. i know my f350 8" lift on 37s take a 10" and it still isnt enough
I'd guess 6" drop would be the ticket but every trailer is different. Check out these Diversitech adjustable hitches. I took a close look at them a few weeks ago at SEMA. The self locking hitch is badass, no more pins and it's got anti rattle, spring loaded balls. I don't know about you but loose hitches drive me nuts.
http://www.etrailer.com/comparison.a...pc2=DTALBM6600 |
1 Attachment(s)
I have a 2004 duramax with a 6" RCD lift running 35's. To tow the boat level I use an 8" drop.
1 Attachment(s)
another
I have a 2001 silverado, 6" suspension, 3" body with 35s. I only have a 6" drop and haven't had a problem in 3 years.
Sent from my iPhone using Tapatalk |
Most standard trailers these days are designed to travel level when the ball is 18" off the ground to the top of the ball. Take a known drop hitch...say a 2"...put it on your truck, measure from the ground to the top of the ball, subtract 18" and that will tell you how much more of a drop you need.
I also factor in the drop in suspension when the weight of the boat is on the hitch to maintain that 18" height. |
I was always told from the dealer, 19" to the top of the ball. So yeah, 18-19" should get you there...
Measuring tape?
It's important to get the trailer level to allow the surge brakes to function correctly.
hey blair what drop did you end up going with on your hitch?... I need a hitch for now but want to be sure it will accommodate a lift down the road.
I went with the B&W drop hitch it adjustable 5" down and 5-1/2" rise. I love it and if you look around you can find it for about 165.00
