Prop recommendations for 04 X-Star?
Dinged the original and figured this was a perfect time to upgrade? Your guidance on how we get a bit more out of the hole when weighted?
Just call Acme directly and they will help you pick the right prop, then ping Chpthril to order it
I am still amazed at the great personal service that Acme provides considering the volume of business they do |
Daryn,
What motor are you running and where are you located? What specific prop are you coming from? Thanks, Spence |
Daryn posted on my behalf while I was setting up my login. It is an '04 Xstar with the 350hp MCX motor. I am located in Dallas, TX and the boat has the factory prop today.
Kyle,
I would check out the Acme 1285 or the OJ 470. You will get a lot better hole shot from either while loaded down. Your top end will decrease but the low end performance will be worth it. Thanks, Spence |
Thanks for the recommendations.
Kyle |
I have a 5 blade prop ill let go for $300 I only used it two or three times.
1 Attachment(s)
can't use that 5 blade on a Mastercraft XStar it needs to be splined 1 1/8
