Board Suggestions? Coming off a Ronix One
Hey guys I would appreciate some feedback on some boards.
Currently Im riding a 2012 Ronix One and I love it, its fast and floaty but I feel at this stage of my riding career I cant use the board to its potential. I have a hard time getting the board on edge when going W2W. I use to ride a 138 Hyperlite Premier and while that board was heavy it was locked in and i loved how easy it transitioned edge to edge. Im 5"10' 180 lbs. My One is a 142 I was looking at the following: 2013 LF Witness 2013 Hyperlite Marek 2013 LF Harley Im looking for a board that is more locked in, transitions edge to edge easily and consistent pop, not as abrupt Any suggestions are welcomed! Thanks for your feedback |
My friend who has been riding the One for a long time just switched over to a Byerly Blunt and says it's the best board he's ridden. At one point he switched from the One to an S4 and back to the One. That's his board history as far as I know it, which is only a few years.
I think the Hyperlite Franchise does all that you are looking for. The only thing is that it is not very locked in, but could be with a little larger fins. The board is very edgy and transitions very quickly from edge to edge. It is a large continuous rocker but keeps its speed well and pops incredibly.
I'll admit its what I ride, but I love the shape so much I try and get as many people on it as possible. It really is a sweet ride. |
Nope, I've ridden the entire line with the exception of the Process. If I wasn't on the Franchise I would ride the Byerly AR1, but its even looser than the Franchise.
If you get a chance to ride the Harley, do it. I have had multiple compliments from friends that have rode mine. It is lose when you want it to be and locks in when transitioning to the edge.
Id like to try the harley. Im interested in either that or the witness. If anyone has feedback from both of those that would be awesome
Rode the Witness for about 4 years, loved it. Great controllable speed, predictable solid pop. Riding the Harley this year, it's fast and rides high in the water. The pop is similar to Witness, not bucking like you may be accustomed to from the One, but higher arching than the Witness. My only complaint with the Harley, is that it can be too fast, creating too much line tension. Not necessarily a bad thing, but It's also kind of heavy, and very buoyant (hard to get it back under you when floating in the water).
I would say you can't go wrong with either one, but the Witness would be more forgiving to progress on. |
Gonna toss out a suggestion to check out the 2012 or 2013 Marek as well. It is similar to the franchise (which I love, btw) but its a little bit more locked in cuz of the larger fins, and changes from edge to edge a little bit quicker (two of the things you mentioned you were looking for in a board) but the differences in these areas arent huge, between the Marek and Franchise. both have super solid pop without being overly bucky, even off of steep wakes.
I chose the franchise because i found it to be a little bit smoother and more consistent overall. but both are very fun boards for sure and definitely worth checking out. |
i appreacite all the feedback everyone! yea right now I have it between the harley, witness, and marek.
If I get the harley should I get the 139 or 143?
Im 180 The website says the 139 is 130-210 and 143 is 150-250 |
go with the 143, i am a little heavier by 10 lbs than you and i rode the 139 harley my landings were kinda harsh, the larger board will give you more surface area and stability all around for landings and chop, i am riding a 142 franchise and LOVE it, rode the harley, BSide and one and the franchise is my fav board right now
If you get a chance check out the Byerly Conspiracy. I left the 2012 Ronix One for the same reasons as you. I've been on the 2012 Conspiracy 56" (142cm) since the end of the season last year and haven't even thought of switching boards yet.
I'm 185, 6'0", I rode a 140 Witness, and now a 139 Harley. The Harley is a fast, shallow riding board already. I don't think the extra surface area would be needed. However, it's a personal preference, but a 143 would feel huge to me.
I suggest the 143. I think you will like it being larger considering it floats higher on the water. Either way you go about it, I don't think you will have any complaints about the board.
any reason you aren't taking a look at one of the other Ronix boards? You said you love your one but want something that edges better. Why not look at the Code 22, William or the Viva?
I would look at the other ronix boards too. I just hadn't heard such positive reviews as I had with liquid force Harley.
I'm open to suggestions to the ronix line too |
I've owned and ridden many boards over the past few years, but in the last 2 it has been the: Harley, Harley Grind, S4, Watson Pro, Watson Classic, Watson Hybrid, Ronix One, Ronix One Timebomb, Ronix Code22.
Between Liquid Force and Ronix, I'd say that the Code22 has the most similar feel to the Harley (it's hard for me to find differences between the Harley, Watson and S4...they all feel the same to me). Both have very consistent pop and are fast. To me, it feels like the Code22 is "easier" to ride than the One. Could just be that it's a new year of riding for me, but I feel like I've been taking tricks bigger and with more consistency on the Code22. Hope this helps in some way. |
I have experience behind the Harley and Watson Classic. The Harley is definitely faster with a little looser feeling in the flats. Both are fun boards though.
So if you were to pick between a new halrey and a code22 based on your experience, which one would you choose now? |
Liquid force rates the watson as looser than the harley. |
I am not quite as abbusive to boards as Jay. I haven't had any problems out of my Harley. I have no experience with the Ronix so I can't comment on it. As far as price goes. 2013 Ronix Code 22: $570 2013 LF Harley: $400 |
What size Code 22 do you ride? Im 180 5'10" and was thinking the 142 |
I went from a one to slingshot kine... I am NEVER going back... Same pop more speed, better landings better control better board... Take a look there
To answer both your questions, in my opinion the kine is the best behind the boat due to its thicker rail, i felt it had the cleanest release vs response and recoil but they had similar characteristics. Edging is not "hard" BUT with that being said you need to make the board work for you. My one used to carve me in like it was on a rail, te difference now is tha I carve the kine in like its on rails, catch my drift? I have literally nothing negative to say about it... Except maybe the fast track doesn't hold bindings as tight... Umm yea but besides that it's perfect for me. In my riding I like to emphasize board control, board feel, and style, and it fits me here. It is loose but you honestly get used to it quickly. It lands very soft, pops very hard, and rides amoothly, I've ridden many many boards and this is my favorite by miles.
Rent a slingshot before buying. It isnt for everyone. I tried a flex board last summer and I enjoyed it. It was the LF Shane Hybrid. It is a playful board. It definitely got me interested in slingshot. I plan to rent one soon. Till then, i will keep enjoying my Harley.
The Harley has the most aggressive 3 stage of any Lf board and bucks more than the one. I have ridden all the boards you were asking about. I have ridden the marek since they changed the design last year and it is exactly what you are describing to a t. It's very quick on edges and pretty grippy on edge but breaks free easier than the one when still. And the pop is very big but consistent as it is an abrupt continuous rocker. I would say if you are looking for consistency in pop a board that leans more continuous would be preferable to an aggressive 3 stage...
Well Im going to look at boards this afternoon. Ill let everyone know what I come home with. Thanks for all the feedback!
I think you should get the 143 if you get the Harley. I am 5'9 an 225lbs. However, multiple friends of mine ride it and they are your height and weight.
Just got the 143. I'm 5'9" 200#'s http://img.tapatalk.com/d/13/06/01/ugage3uz.jpg
Well I ended up with a Harley 139 with the 10-12 boots. Picked her up at Sun and Ski and if you dont like the ride you can switch to any other board they carry which is the full line of liquid force and hyperlite. I rode it yesterday and love the board so far. Its locked in going to the wake but im also able to break it free for butter slides and on the wake too. Ill post pics later!
I am glad you enjoy it. Thanks for responding on what you decided to go with.
It sounds like inconsistency is really the core of your displeasure with the One? If so, I'd lean towards a board with closer to a continuous rocker. Three stage rockers present a different view to the wake if you come in at slightly different angles making the pop more varied while continuous rockers present closer to the same view to the wake... More predictable pop. Think of bouncing a football or soccer ball off the ground. A football is like a three stage and it will bounce differently with small variations in the angle y throw it down. A soccer ball is the continuous rocker and presents the same angle to the ground/wake no matter how it hits so is predictable how it bounces. I don't follow all the board models, but I think many of the slingshot models have continuous rockers and I've read good things about them. Vaguely recall the Marek which others have recommended to you being a hybrid or near continuous rocker and might do well for you as well.
