Sanger V210 Ballast Question
Hey, I think my impellar went out on my front pump thats located under the drivers dash.. Can anyone confirm that the 02 V210 came with a Jabsco pump (reversible)? I want to replace it with the green Imellar.
Thanks |
I believe in 2002 Correct Craft was using an Aerator Pump setup. I think they used the Rule pumps. Open it up and take a look.
I think he was asking about a Sanger not a CC:)
Isaac, we just installed a ballast system in an 03 V215 and it did not have reversible pumps, config was 1 fill and 1 drain to BOTH rear tanks and 1 in, 1 out to the belly tank.
Different year/model, but should be similar set up. Do you have the rear tanks? If so are they running reversables? |
mine for sure has a reversible pump in the front.. its all it came with stock. I added the rear tanks myself but used attwood tsunami 1200GPH pumps to fill and drain.
