ARC Audio KAR 1000.2T
Anyone have any feed back on this amp? It suppose to run 900 watts at 4 ohms bridged. I'm considering running it at 3 ohms but need to know if it is stable in bridged mode. I called ARC but the guy I talked to seemed to not know a ton about it for some reason (they don't make them any more) and misquoted me numbers on it. I would be running two of them, one to each sub.
Its either this or do 2 Alpine PDX 1.600 to each. Subs are JBL GTI 10 Thoughts? |
I have one but havn't installed it yet. I have heard great things about them as far as durability and quality. I know there is someone on here that has them installed in their set up. Hopefully they can chime in.
Here is a link to the manual from ARC's site....
http://www.arcaudio.com/archives/KAR1000t.pdf It says that it is stable down to 2 owms mono or 1 ohm stereo....Should do 3 ohms woth NO problem.... Cheers Scott |
