WakeWorld
WakeWorld (http://www.wakeworld.com/forum/index.php)
-   Wakesurfing (http://www.wakeworld.com/forum/forumdisplay.php?f=87668)
-   -   '06 VLX (http://www.wakeworld.com/forum/showthread.php?t=616882)
sarahpark 08-19-2008 7:13 PM
i have a '06 VLX with the two rear and centre ballast tanks. I also have the power wedge. I have played around with the wedge and tanks as well as the speed and cant really get a nice surf. Its hard to find people to go with due to my work schedule so at best i probably have 750 lbs of additional "people" weight in the boat. Any tips on how to get the nice surf without spending a ton on fat sacks would be appreciated
bac 08-19-2008 7:24 PM
Hate to be the bearer of bad news, but you're going to need some type of additional ballast or alot more people (within reason of course) to get a good surfable wake out of that hull. Most of the guys I know that surf the new VLX hulls run between 2,000 and 3,000 lbs of ballast on top of the factory ballast. You'll also want to put a some weight up front, I would say a few hundred pounds. I surf a '00 VLX and we run at least 2,000 lbs of ballast, not including people and gear. Your boat will throw an awesome surf wake, it just takes a good amount of ballast to do so.
