I left my boat in High Rock Lake this weekend. This lake is notorious for its sediment loads. Any way to get the "High Rock Ring" off my boat w/o damaging the gelcoat? Thanks in advance
acid wash?
Ryan is right. Try StarBrite Hull Cleaner. It is a mild acidic cleaner. I'm not sure what "high rock ring" is, but this cleaner works great getting off lake scum, aka dirty water, stains, etc. I've used it several times on my Supreme and it works great. Apply it with a damp sponge and rinse off within a couple of minutes. If it's real bad, you may have to reapply. I've always washed the boat after applying, just to make sure no acidic residue is left behind. Also, I'm fairly certain it will strip any wax job off the boat; that's the big downside. <BR> <BR>You can buy it at West Marine, Overton's etc.
I like "crazy clean" from Sprayaway #31
I'll second the Starbrite. It has worked well for me in the past. I have also seen it at Walmart if that is more convenient.
Babes is also money
3rd the starbrite hull cleaner. last year i left my boat in the water for most of the summer pulling it out about once a month to deep clean it and the starbrite hull cleaner works miracles.
Another happy Star-Brite Hull Cleaner customer.
StarBrite it is....thanks again
Here is a plug for FSR (Fiberglass Stain Remover).. It's another acid wash, but I swear by the stuff. It's gel so its a little easier to work with. Since my project car has taken up residence in the garage, my boat is staying tied up at the dock more this Summer and my lake is notorious for scum lines and mineral deposits. I just wipe on some FSR when I pull the boat out and the stains just vanish. <BR> <BR>Make sure that you wash and wax after use of any these products or the stains will just be worse and show up faster the next time.
On the Starbrite hull cleaner does it affect the paint on the trailer?
It can. I've done my boat twice. Both times I was really careful to make sure that the trailer was wet before I started. If I saw any hull cleaner dripping on the trailer, I quickly rinsed it off. The gel stuff kdr mentioned sounds like a great idea. If it is the same acid type, I'd try it. <BR> <BR>Jman
I think I'll wrap the trailer in cellophane to make sure it's protected.
