Im looking for a bimini that will work with an extended pylon on a 94 ski nautique. Ive seen pictures of it but it was back in the hayday of the extended pylon. If anyone knows of a manufacturer of one it would be a big help. <BR>thanks <BR>david
You can just get a zipper put in one where the pole goes through....
If you already have a bimini, just put a hole in it.
Had an uphosterer put a hole in my old boat. Was $75 and well worth it. Haven't ever seen one already made as the positioning might be off depending on where hte bimini mounts on your boat.
On my old boat I put two holes in my bimini, one for the pole and one for the cable. It worked great. We cut the holes and then sewed the trim stuff on the openings to help prevent rips. It was a pretty easy job and it made the bimini much more useful. <BR>
Fly High makes one that can be used with or w/out your extended pylon up, also it is made out of Sunbrella and comes in black, blue, red, yellow,& gray. <BR>Check out fatsac.com or give us a call. <BR>414-964-3668 <BR>Thx.
